Display individual LACP statistics for specific ports to manage network performance.
View LACP statistics:
Switch:1>enable
Switch:1#show interfaces gigabitethernet statistics lacp
                                Port Stats Lacp
PORT TX     RX     TX        RX        TX            RX            RX      RX
NUM  LACPDU LACPDU MARKERPDU MARKERPDU MARKERRESPPDU MARKERRESPPDU UNKNOWN ILLEGAL
1/39  0        0        0          0          0               0    0       0
1/40  0        0        0          0          0               0    0       0
2/1   0        0        0          0          0               0    0       0
2/2   0        0        0          0          0               0    0       0
Use the data in the following table to use the show interfaces GigabitEthernet statistics lacp command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}  |
 Identifies the
                                    slot and port in one of the following formats:
